ZWOASI1600MM_NOISE2.jpgZWOASI1600MM_NOISE.jpgI've been using my new 1600MM cooled camera for about a month now and I see just about all images covered with columns of bright pixels... darks and light images all show these bright columns across the images....
First attached image shows single frame image at 100% and 400%
this image was taken at gain 200 offset 10 and temp at -30 C ... but I see this noise pattern in everything regardless of gain, offset or temp
Second attached image shows result of 19 frames processed and stacked ( using Darks and Flats )
at 100% .... showing that this noise does not process out of the images.... the 19 frames were 360 sec exposures taken at gain 400 offset 10 and Temp -30C
can anything eliminate this noise ???
Brad Wallis
