Hello,
I have an ASI1600MM-cool that I bought earlier this year. The weather has been pretty poor here, but I have finally had a chance to try it out in a couple of configurations.
I believe that the sensor in the camera may be tilted. I cannot get properly formed stars across the entire field. My automation focuses on a star in the center of the field, and that area is fine. The right side of the frame tends to be the place where the problem is greatest. This is true if, regardless of the orientation of the camera (ie. if I rotate the camera, the problem stays in the same place in the frame) and regardless of the point in the sky where it's aimed (it is not a flex problem). The same problem shows up with two different scopes that I've tried: a 384mm focal length refractor with field flattener, and an SCT at 1655mm. I have attached an image from the SCT with samples from the center of the frame and each corner to show what I am seeing. If this looks like some problem other than tilt, I would be interested in opinions.
I have not yet had a chance to bench test the camera off of the scope to test for orthogonality of the sensor. My question is, assuming that I can confirm a tilt, is there a way to adjust it in the camera, or will the camera need to be sent in for repair or exchange?
Thanks.
-Wade
