there were 52 images stacked. used sharpcap 3.0 to capture, no darks no bias. lights only
and no ascom driver was involved.
I have found that the debanding tool in PIX insight does remove the banding if you rotate the image 90 degrees and run script.
as I understood this was only meant for canon sensors
does the sony chip suffer the same problem?
Is there still an issue with camera?
Is there a firmware upgrade available for the camera
oh this was a asi1071mc too.
cheers
Clive.
