I'm using the ASI071. In ASCOM it seems you can set the gain and offset of cameras.
I've been using sharpcap with the ZWO drivers. I can set the gain in sharpcap, but how do I set the offset? I'm sure there's a simple answer ??
offset is also called "brightness" under SharpCap
