Sam wrote:james_screech wrote:I have APT set to ASI (1) ASCOM driver and that always selects the 1600MM-C (as I want). I have PHD2 set to ASI (2) ASCOM driver and this also by default connects to the 1600MM-C camera. Shouldn't one ASCOM driver default to the 120MM camera as there is no point in using the same camera on both drivers.
I always connect APT to the camera first (to start cooling) and then start PHD2 and connect some time later.
James
Hi James
the 2 ASCOM driver is the same and it always pick up the first camera
it doesnot matter it select which camera by default because you can change it
Wouldn't it be better if driver 1 defaulted to the first camera and driver 2 to the second? No one would ever want to use the same camera from both drivers (I wonder what would happen if two applications tried taking images with the same camera at the same time).
Or better still the two drivers should remember the camera they were connected to from the last session and default to that.
Yes you can change the camera connected to each driver but its an extra step that is easily forgotten, especially when imaging / guiding software comes back and tells you that it has connected to a camera.
James
