I am having issues with using a ASI1600MM in SGP and a ASI120MM as a guide camera. Both are running through ASCOM via SGP. The 120MM has problems connecting with PHD2 and has 'star lost' issues when calibrating. I've ran the wizard and everything seems to be ok. When i go into the brain, PHD2 always defaults to the ASI1600MM when changing gain or any other parameters. I've loaded the ASI120 under 'ZWO Camera' in PHD2 and loaded under ASI Camera (1) and 'ASI Camera (2) and even switched back and forth on changing the same settings under 'Equipment' on SGP to reverse the order.
Sometimes this worked and other times it did not. On a couple of occasions when it did lock and guide, it would lose SNR after a few minutes or PHD2 would lose the star despite it being anywhere from a mag 6 to mag 10. When I close and restart both SGP and PHD2, sometimes it connects to the 1600 and other times to the 120. I have to continually change manually.
Are there issues known of the cameras battlling each other and PHD2 not recognizing the correct camera? SGP always defaults back to the 1600 whether on ASI Camera (1) or camera (2). HELP!!!
