Hello,
Is the window on the ASI1600MC-cooled just AR or is it also IR Block?
Thanks.
Ross.
it's AR window
Thank you Sam, but are you sure?
My camera was bought in May 2016 so is one of the very first asi1600MC cooled cameras made.
I remember reading at the time that the 1600MC did have an UV/IR cut window and the asi1600MM only had an AR window.
Ross G wrote:Thank you Sam, but are you sure? My camera was bought in May 2016 so is one of the very first asi1600MC cooled cameras made. I remember reading at the time that the 1600MC did have an UV/IR cut window and the asi1600MM only had an AR window. Ross.
We never use UV/IR on 1600mc-c
Thank you for clearing that up Sam.
I will now get a UV/IR cut filter to put in my imaging path.
