Hi all,
I seek your valuable suggestion as to which ZWO line of OSC camera is a reasonably good one for DSO imaging through C9.25 SCT. As a beginner, I don't want to immediately go for a monochrome one - maybe that is once I am confident with OSC camera.
Thanking you in advance.
Rajib
Digboi, Assam, India
you can consider ASI1600MC-Cool or ASI071MC-Cool
Thank you so much for your suggestion. I am also considering for ASI1600MC-C. But in one of the CN forums, someone mentioned that ASI1600 camera may not be that good for C9.25 due to its long FL. However, I have one f/6.3 FF/FR to combine with the C9.25 SCT. Will you kindly confirm if ASI1600 is OK with this combination (C9.25 with f/6.3 FF).
Hi Rajib
you are correct the pixel size is a little small with C9.25 f10
But it should be ok after the reducer
anyway, ASI071 is the most suitable one
