Specifically, I have 2 asi224mc cameras, 1 will be for guiding, other for imaging.
I am using the celestron off axis guider. Also using a 6.3 reducer. Ota is.the c9.25.
First problem is getting the 2 cameras to be read at the same time. Although the 2 say connected, if you check both, the feed is only from 1.
Second,.if I hook them up individually, they read fine. But the main camera when in focus, results in the guider out of focus. The guider has to rack in all the way, and is still out of focus.
Anyone can help??
