Hi,
This is regarding SGP and the ASI1600 camera. SGP has a nice feature that will disconnect your equipment automatically when the sequence is finished.
When this happens a dialog pops up, which I am somewhat sure is from the ascom driver for the ASI1600, that asks, to paraphrase: "do you want to shut off the camera cooling". What this does is then stop the whole process of shutting down the camera cooler, which is really what I would like to turn off more than any of the other equipment.
Bottom Line: Is this dialog from the asi1600, and if it is, can the next revision to the drivers plz make it either go away or atleast configurable for automation?
John
