When I connect the camera (1600 MMC) + filter wheel and go to "connect" the filter wheel it says "fail to calibrate" .... watching it work as it attempts to calibrate it never ends up in the same filter position when I attempt to do additional calibration runs.....
It used to work fine before I went and added in new filters... I just did a connect and it said "OK"
( I am using and always have used Images Plus 6.5 to run the camera )
NOTE.... When I was adding in the new filters... I lost a screw and I had to remove the filter wheel from the housing ...
HELP !!!
Brad Wallis
