I never push the cam @-15C and never see ice but i can visually see dew @-10 C on the sensor with a brand new camera (2 nights usage)
Is there a serial number for the first 071 batch, or something i can check to see if i get the long screw without opening the camera ?
Can i check for this defect externaly ?
I buy this cam in the first day of july 17.
I'm preparing for the summer sessions on august and really want to avoid opening the cam since then.
Did you have internal photo of the ASI071 as you provided for the ASI1600.
I can only see 2 dessicants tabs looking thru the clear AR glass.
As i understand, the better method to dry the cam, is to open it and change the Four dessicant tablets with four hot new tablets, then seal the cam and wait for more than 2 days.
thank for your help
