Hello. I'm new here. I've tried to do some research but unsuccesfull. I have ASI034MC. Recently bought only for guiding with guiding scope. Is it possible to guide without PC? There is an autoguiding port on my eq3-2 synscan goto. I'm clueless. Starting on astrophoto. Every wisdom helps.
no, you need PC or Embed system such like PI to control it
Many thanks. Found sth like this- connecting ASI with PC via USB, and Synscan with ASI via autoguider port. As I understand, it should do the trick? Ofc some guiding software( phd, maxim etc etc).
Sengoku wrote:Many thanks. Found sth like this- connecting ASI with PC via USB, and Synscan with ASI via autoguider port. As I understand, it should do the trick? Ofc some guiding software( phd, maxim etc etc).
yes, you are correct
