Still learning about my ASI1600 cool. Going to various forums, I came across a statement that one cannot create a dark frame library for this camera, as I always do for my other cameras. Something about it "resetting" itself each time it is powered up. Is this really the case? That would be unfortunate since I usually do my dark frames separate from my imaging time.
Peter
you can build your dark frame libraries
just make sure all data collected under same condition
same exposure, same gain, same offset, same USB Limit, same USB port
Thank you for the response. I appreciate it.
