rgsalinger wrote:With short exposures I am getting a huge amount of fixed pattern noise. This is completely messing up my plate solving and my focusing. I'm attaching a screen shot of an example. What can be causing this?
Rgrds-Ross
Dear Ross,
Hi - looks like you have this binned 2x2. What does this look like unbinned? I also came across a strange pattern in my images where every 8th column had almost zero values - it looks a lot like your image - see this post:
http://zwoug.org/viewtopic.php?f=21&t=7336http://zwoug.org/viewtopic.php?f=21&t=7336
My problem is intermittent - it came and went within one imaging session, was there for the next two days, then went again.
I did manage to platesolve though (I focus manually, so don't know if it causes a problem here). I'm a bit surprised that you are not able to platesolve the image you posted - I've seen TSX cope with much worse.
Colin
