Hi,
I have an ASI1600MC-C bought in April and I think it has sensor tilt. I tested my scope with my dslr and the stars in the corner are round. I have checked back spacing from the focal reducer/ field flattener and I am at manufacturer spec. I tested the camera at back spacing from -5mm to +5mm at 1mm increment spacing and the results are the same. I have rotated the camera and the issue always remains in the same place on the sensor. I bought the tilt adjuster and have tested tilt at 0.5mm, 1mm, and the maximum amount of tilt I could get on the adapter with tilt at the top, left, right, and botton and no adjustment I make has any effect.
Any help is appreciated.
Scott
