• SDK & Driver
  • Is there a way to guide in 12bit mode with ASI120MM?
Hi, I chose the ASI120MM over the QHY 5LII because the QHY won't let you use the ST-4 port if you guide in 12bit mode. Now that I have the ASI camera it appears there is no way to guide in 12bit mode at all. Is there any way possible to use this as a 12 bit guider?
I'm not sure I understand. Why would you want to guide in 12bit mode?
I see no reason.
Currently we don't provide other way.
Write a Reply...
