chad wrote:Hi,
Please download this attachment. and try to upgraded the firmware again.
Thanks
chad
Hi Chad,
I downloaded this attachment and used it to flash my old ASI120MM, and the command succeeded, but now the camera is not functioning at all.
Here is the command I ran (from the x64 directory):
./zwo_FWTool_USB2 -i ../firmware/ASI120MM-compatible.iic -t li2c
The command succeeded, but after this the camera no longer functions.
Here is the output of dmesg covering the time just before the firmware was updated to just after:
usb 1-2: new high-speed USB device number 13 using xhci_hcd
usb 1-2: config 1 interface 0 altsetting 0 endpoint 0x82 has invalid maxpacket 1024, setting to 512
usb 1-2: New USB device found, idVendor=03c3, idProduct=120a
usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-2: Product: ASI120MM
usb 1-2: Manufacturer: ZWOptical company
usb 1-2: SerialNumber: 00000
usb 1-2: reset high-speed USB device number 13 using xhci_hcd
usb 1-2: USB disconnect, device number 13
usb 1-2: new high-speed USB device number 14 using xhci_hcd
usb 1-2: device descriptor read/64, error -110
I unplugged the camera and then plugged it back in, but to no avail.
I then tried to update the firmware again, but I am afraid the damage has been done, because now zwo_FWTool_USB2 reports the following:
Error: No FX2LP device found
Is there any way to recover this camera?
Leonard
