If you change the camera and change cable and the problem is still exeist. I think the problem will cause by your AVX mount.
There is two posibilities:
1. AVX mount Guide port is damaged, cannot realize the command from computer.
2. AVX mount RA worm and gear have a big gap. So when the guide camera send the command to let the mount move to east, the mount didn't finished the gap then the calibration is already fail.
I think the second posibility is more identical to your description.
If the worm and gear have a big gap, you need to use some tools to make it tight again.
