Hi guys
think there might be something strange about my latest RGB capture of the veil nebula. I dont know how this happened but it seems that most blueish parts of the nebula complex appear green im my combined rgb image. (pls have a look at the attached file, its just combined and autostrechted). Even after processing the blue parts of the nebula still remain greenish
What am i doing wrong? The images are 18*120->R, 12*120->G and 16*120-B and than combined taken with an ASI1600mmc on a 8" Lacerta Newton. I am using the Mini FW with the ZWO 1.25" RGB filters. I've heared that only the ZWO 1.25 G filter lets pass OIII. May this cause the problem?
If you want you can have a look at the r, g and b image here:
https://www.dropbox.com/s/du2aa4ta2a5ay3g/rgb_registered.zip?dl=0
Thank you guys
