thanks for the quick reply.
i had a conversation with you about the capture/video mode, i also sent you a test application. it's nice the phd uses video mode, and seems quite stable on win7. unfortunatelly very unstable in win10.. :(
i am using the asi120mm for guiding. if i use directshow, is there any way i can use the camera built in ST4 for guiding?
i was also planning to buy one of your new camera, like asi-1600mm-c. do the new cameras also have this unstability, or do they work smooth?
