Okay let me try again:
0) Install ZWO ascom driver 1.03.7
1) Install and run CCDciel imaging program.
2) Setup as camera ASI1600MM, run setup and set the camera parameters as required.
3) Connect all. (The camera will connect without problems, camera indication will turn green)
4) Stop the CCDciel program.
5) Restart the CCDciel program, connect all => This will result exception error divide by zero. The camera indication will not turn in green.
The problem in step 5) will not occur with ascom driver 1.02.25.
Can you reproduce this problem?
Regards, Han
