Hi Beo,
Pardon, I don't know what you're going to do now.
Let me sort out the ideas.
1,For ispy, Neither 290MC nor 178MC can be used. And ispy use the DirectShow driver.
I will offer you a 178MC DriectShow driver in the attachment, and I think it should works well. You can try it.
2,For AllSkeye, use ASCOM dirver, it could not control the auto exp and so on.
If you have to use auto exposure, then forget the ASCOM driver. Because auto control is not in the ASCOM driver protocol.
3,USB2.0 is more stable than USB3.0
I think you made a mistake. Their differences are only in speed and power. If your camera doesn't have cooling function, power is enough. And speed only affects frame rate。Both of them shoule be stable.
4,missing pixel and the image is not correct.
I am not sure why. So I need you to tell me the sequence of your operations in more detail. And don't worry about it, I guess it should be a setting mistake.
So, Let's solve it one by one 。
The attachment is the 178 DirectShow driver. you can try it in Ispy. It should support the auto control. Maybe it still miss pixel and the image is not correct, but you can try other functions. Please try it and tell me your result. Then we will talking about the missing pixel. OK?
Thanks
chad
