arbydog wrote:Sam wrote:arbydog wrote:If I were to use a 2" UV/IR cutoff filter like the one you sell, where would it fit in the optics train. I have the AS1600mm-cool ==>Filter wheel==>OAG==>focal reducer
I don't see a good location to attach this. Would a 1.25" filter work better, somehow?
why do you need 2“ cut filter if you already have the filter wheel
Sam,
I am getting significant bloating on the blue and luminance filters even after refocusing. The Baader UV/IR cutoff I plan to use cuts off about 410nm where the ZWO goes down to 380. I am hoping that will help tighten up the starts in the blue and luminance channels.
I use my ASI1600MM-C with the 'new' ZWO LRGB filter set on a TS 80 mm triplet apo refractor with 0.8X reducer.
I also observed notably larger stars with the blue and luminance filters.
After much trouble-shooting, I discovered that the telescope optics could correctly focus light down to about 420 nm (deep blue), but the filters in front of my ASI1600MM-C camera passed light all the way down to 385 nm (violet). The light between 385 and 420 nm is always slightly out of focus, even with my triplet apo lens, so this creates colored halos and other artifacts around the stars.
After reading about the UV cutoff, I purchased a 2" Baader UV/IR-cut filter and put this in front of my focal reducer.
This filter should have a 420-680 nm passband according to their transmission curve.
The sharpness of the blue channel improved indeed and my star color is now also more accurate.
Most light pollution suppression filters also have a UV/IR-cut function, so you can probably use one of those instead of the Baader UV/IR-cut filter if you have one of them laying around.
Note that the LRGB filters are not faulty, it is a limitation of refractor telescope optics.
These LRGB filters are probably perfect for reflector telescopes (Newton, RC), since they focus light of all wavelengths at the same point.
