Hi
I have some questions regarding the new ASI174MM Mini.
Is it possible to attach the cam to an 2" focuser on a f4 Newton (150/600)?
Should I expect heavy vignetting or impossibe focus distances somehow?
I would like to use it both as guiding cam and as main cam on my
f4 newton.
I guess the sensor is the same as the normal 174MM.
Is the driver support the same as the normal 174MM with indilib?
