I've only had the ASI1600 a few days. It's taken some nice images and I like the SharpCap software.
My problem is getting USB 3.0 speeds.
I have swapped cables, tried a powered hub and different power supplies for cooling. Still only USB2 speeds. My laptop ports are fine with other devices.
It finally started working (on an indoor bench) at near specifications when I powered up the 1600 in a different order. My full frame speed changed from 2.1fps to 14.7fps.
At this point, I'm not sure if it was a fluke or what. I'll be out with the scope tonight. Anyone have any tips or insights?
