this is because we tested this camera at summer and the cooler cannot reach deeper
so we just didnot show it
but you can image the value if the temperature is lower
because dark current value is linear
compare with 1600, you should compare at same degree such like 0 degree
ASI1600 0.03e/s
ASI294 0.06e/s
and notice that the pixel size difference 4.63 vs 3.75
then compare the area of one pixel: 4.63*4.63 / 3.75*3.75 = 1.5
so 0.06e/1.5=0.04e which is a little higher than 0.03e
the image quality from 1600 is better than 294
there is very faint random horizontal noise and amp-glow with 294
you can compare both darks
