You know it's funny you brought this topic up because well, let's just say I was planning to buy a laptop because I thought my Laptop USB ports were bad, but they never have the problem with any other devices that are USB that I try, I have the same problem with my ZWO ASI120MC the day of the solar eclipse I was doing video of the sun and trying to show my parents well the dang laptop would freeze and I'd have to restart the laptop I figured eh! maybe the laptop is just running to hot.
I ended up having a few of my videos I doing with the ZWO ASI120MC they're unplayable because I guess the software wasn't able to convert the video before the laptop froze you need to stop the recording not just force your computer to shut down otherwise the software won't convert the video and it will be unplayable...
Anyways so every time I connect this ZWO ASI120MC some times it will randomly freeze my laptop if I happen to touch the camera, for example I'd switch the eyepiece for the camera or camera for eyepiece in the process of doing that it would lock up my laptop only way to get the laptop to unfreeze is to unplug the USB cable from the laptop and then it unfreezes the laptop.
But their have been a few times the camera has made my laptop blue screen and I'm using Windows 7 64-bit and take in mind I did a clean install of Windows 7 reformatted the machine and then installed Windows 7 did the updates installed nothing but the ZWO driver from the website and installed Sharpcap connect my ZWO with the fish eye lens on it load up Sharpcap and enable to ZWO from the camera list and just let the camera look at the roof and it's blue screened my laptop a couple of times or it will just freeze my laptop.
By the way my laptop is a HP EliteBook 8540w I'm pretty sure the laptop is good enough to use the camera with and for imaging.
Downfall is well the CPU is power hungry so running off a battery is not do able the Laptop is old Business workstation the hardware not the same as it is for the consumers hardware.
