Is this camera compatible with Windows 10 while being USB 2.0? The reason I ask is because I'm having issues with an ASI 120MC camera where it worked perfect under W8 but under W10 it works for about 5 seconds and then drops to around 0.2 FPS. I have not found a fix for it but need a new guide cam anyways and I'm seriously looking at the 174MM mini but will hold off if it won't work with W10.
Thanks
Hi,
Yes, you can use 174MM Mini with Win10 in usb2.0, it will work fine.
For 120MC, it is too old, So it worked unperfect with win10. But 174MM Mini is our newset product, so it is fine.
chad
