Hi Sam,
Hi All,
Here is my first image with testing camera ASI 385.
M76 is an interesting target in short exposures because it's not a very bright
planetary nebula and it shows some faint extensions. Moreover a difficult
double-star is visible at the center of nebula.
Here I mixed 5 seconds, 2 seconds, 1.5 seconds, 1 second exposure. Imaging
session includes2 nights (25 and 26 October) but I have fog which cuts a part
of the light. So bad transparency.
I choose 8 bits during capture, not the best idea for sure. I will use 16 bits
mode next time.
The anti-amp glow works fine !
Only a little problem : on the Raw image, a strange phenomenom appears : stars are
saturated but the level is not at 254 as expected for 8 bits mode. It seems that
the dynamic is reduced or cut by a threshold ? Very strange. If gain is lowered, the
levels of saturated stars are also lowered. Please Sam, could you take care of this
problem ? :?:
SETUP :
Newtonian Orion Optics 300 mm F/D 5.3, on EQ-6 Mount
ZWO ASI 385 without filter,
2595 x 5 seconds exposures.
1319 x 2 seconds exposures
2053 x 1.5 seconds exposures
4370 x 1 second exposures
Gain = betwen 37and 400.
Darks.
Visual sort out of Raw images.
Registration with DSS.
Processing and post-processing with Iris + Photoshop.
Final image, resized at 110% :
5 sec Raw image at 100% :
Albéric
