As to the claims from sbig with 10 hz....
http://diffractionlimited.com/product/ao-x/
Well, they say:
For STX cameras, the AO-X stacks on top of the FW7-STX and STX Guider
And what does the STX guider specification say:
http://diffractionlimited.com/product/stx-guider/
Full Frame Download: 0.13 sec
Additionally, their guider is an old KAI-0340 ccd chip from Kodak.... Quantum efficiency is claimed to be 55.... That's lower than my old lodestar which has 65 or so...
With that you are basically guaranteed to need exposures longer than 1s... Maybe some rare times you will get a guidestar with 0,5s exposure time...
and to that come 0,13 sec download time, and then maybe 0,1sec computing time and sending the correction... That is 0,73 sec...
And there goes sbig's nonsensical 10hz claim....
If one wanted to do this, then one probably would need to have usb-c and a camera firmware that can download only a small section of the image if needed. Or perhaps even to do the entire guiding in the ao. That is, the laptop is only used to set the parameters, manually select the guidestar, observing whether guiding works, but everything else (the real guiding process) works internaly in the ao...
This may remove the frame download and windows/linux guiding software bottleneck...
If the guiding chip is then a sensitive cmos, then one probably could really talk about more than 5hz if the ao can move the glass really fast....
