Hi,
testing again on Linux now with the ASI178MM camera. That cam is giving me a lot of problems. Used oaCapture, Planetary Imager and now the first Linux version of FireCapture.
Tested on several machines, different USB ports and different cables. All (Linux) software suffers from severe time-outs. Seems to be related to the speed of the machine (happens less on my 4790K) but it happens.
I have installed 1 machine which is multi boot: Win10 and Ubuntu 16.04 (kernel 4.10); and tested the camera running Windows 10 (FireCapture and AstroGenika). No problems occurs, and camera runs at maximum speed. Booting the same machine with Linux (same cables, same ports ...) and test with Planetary Imager or FireCapture, problem occurs. Reducing USB traffic to 40% does not solve the problem (little bit better, but not gone) Have recompiled Planetary Imager with a longer timeout for reading video data (5 seconds : ) and that helps, but framerate goes down dramatically. So not usable.
Every time a time-out occurs Linux DMESG shows following line:
WARN event TRB for slot xx ep yy with no TDs queued?
So guys what's wrong here?
Camera firmware
ZWO Linux ASI SDK
Linux USB driver
Think we can exclude computer hardware or cable problem sice same machine with W10 gives no problem
Wonder what would happen if I would start testing an ASI1600?????
Regards,
Paul
