Recently I've purchased a Rock64 single board computer with USB3 port to control my ASI 174MM-Cool and filter wheel.
https://www.pine64.org/?page_id=7147
I use Ubuntu Mate (latest community pre-release) as operating system and have the latest INDI software installed. The camera connects fine, but the filter wheel is completely unresponsive. I tried the following combinations, all without success:
1. ASI on USB3, efw on ASI hub
2. ASI on USB2, efw on ASI hub
3. ASI on USB3, efw on USB2
4. INDI CCD simulator, efw on USB2
5. ASI & efw on Raspberry Pi, running the same setup (this works flawlessly)
Both the camera and the filter wheel are visible in the usb list, and indiserver can see the filter wheel. It can send commands to the filter wheel, but these get queued. The connection indicator in Ekos/Kstars lights yellow, meaning that connection is in progress, but never finishes.
I've posted this problem on the INDI forum, but it seems that nobody else is using this hardware combination.
http://indilib.org/forum/focusers-filter-wheels/2776-problems-connecting-to-zwo-efw-rock64.html
The reason I test this combination is that the Rock64 has a fast USB3 port, so faster image download, and possibly less amp glow (?), than the Raspberry Pi.
Does anyone have experience with this computer? What can I do to test what's going on?
Or can I recompile the efw driver for this system?
Any suggestions to come to grips with this issue are appreciated.
TIA,
