Hi Sam,
Thanks for replying. I had emailed earlier, and had a discussion with Sean. The first recommendation was to go with the 294pro. However, the 6 inch Hyperstar can only illuminate a sensor that's 16mm or less. Both the 1600pro and 294pro are larger sensors, and would waste a lot of sensor space.
I ultimately ended up ordering the 385 cooled from your online site. Please let me know if this is the wrong choice, and I can cancel and change the order.
Another question is that I'll be imaging in 28-35 degree weather, with 15-20 second subs. Will the cooled 385 be a much better option than just using the normal 385?
Sincerely,
N.
