Sam,
Can you confirm whether the ASI EFW works with TheSKYX on the RPI3?
Software Bisque was able to confirm the ASI1600MM-Cool and ASI174MM worked.
Thank you
Sent from my iPhone using Tapatalk Pro
Hi maudy,
We had tested it, it works fine.
It should be include defaultly. You can try it.
If it failed, you can use it Through Plugin:
http://astronomy-imaging-camera.com/software/TheSkyX_ZWO_EFW.tar.gz
Thanks
chad
Perfect Thank you.
Woww. Thank you a lot.
