I will be shooting with a 224mc and 8-12mm lens untracked. What are good meter capture settings. Shooting location should be pretty dark
for video imaging, you need one 4mm or 6mm lens
the aperture of 2.8-12 is too small
oh, I am using the CS lens from ZWO. Aperture is 1.4 I think
wargrafix wrote:oh, I am using the CS lens from ZWO. Aperture is 1.4 I think
the real aperture should be 2.0
https://astronomy-imaging-camera.com/products/accessories/cs-lens-2-8mm-12mm-f1-4/
this one?
wargrafix wrote:https://astronomy-imaging-camera.com/products/accessories/cs-lens-2-8mm-12mm-f1-4/ this one?
yes
I have that lens. What are good meteor capture settings? Will be using Sharp cap.
you can set it to 1 or 2s exposure and capture one night
Thank you! Should I use dark subtraction?
wargrafix wrote:Thank you! Should I use dark subtraction?
usually you don't need
but you can use if there is hot pixels
