Hi,
I am having problems cooling my ASI1600MC-Pro. I use it with a 12V 3A power supply, and with USB 2 connection to a laptop. Software is APT.
When I start cooling with APT parameters set as:
Target temp: -10C
Cooling step: 3C
Pause: 5
Timeout: 500
I get no cooling. The fan is running, but the power supply draws only 7W of power. Is there a way that I can test the cooling without APT? I have asked Ivo at APT and he has checked the logs and there are no errors showing, until the cooling times out after 500 seconds without reducing the temperature more than 2-3 degrees.
Thanks,
Phil
