and the dmesg command on fedora (camera plugged) gives:
only the last relevant lines
usb 4-2: device descriptor read/64, error -110
usb 4-2: new full-speed USB device number 3 using uhci_hcd
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
virbr0: port 1(virbr0-nic) entered blocking state
virbr0: port 1(virbr0-nic) entered disabled state
device virbr0-nic entered promiscuous mode
virbr0: port 1(virbr0-nic) entered listening state
usb 4-2: new full-speed USB device number 4 using uhci_hcd
usb 4-2: device descriptor read/8, error -110
usb 4-2: new full-speed USB device number 5 using uhci_hcd
usb usb4-port2: unable to enumerate USB device
fuse init (API version 7.25)
usb 2-1: new high-speed USB device number 3 using ehci-pci
usb 2-1: device descriptor read/64, error -110
perf: interrupt took too long (2514 > 2500), lowering kernel.perf_event_max_sample_rate to 79000
perf: interrupt took too long (3144 > 3142), lowering kernel.perf_event_max_sample_rate to 63000
perf: interrupt took too long (3931 > 3930), lowering kernel.perf_event_max_sample_rate to 50000
usb 1-4: new high-speed USB device number 6 using ehci-pci
usb 1-4: device descriptor read/64, error -110
usb 1-4: new high-speed USB device number 7 using ehci-pci
usb 1-4: new high-speed USB device number 8 using ehci-pci
