Hello everyone, I'm new to the forum and I've had a problem to submit to you:
I have an ASI385MC but I can not tell if the ST4 port is working properly to use it as an autoguide.
In PHD2 I select ZWO ASI Camera in "camera" and I see the correct model connected to the PC. Then I select ASI ST4 Telescope Driver (ASCOM) to check the mount but tells me that no peripheral is connected (no ASI camera detected).
The same problem appears in Maxim Dl, the camera acquires images even in DS Video mode but I can not figure out if the mount output is corrected. When I select the ASI ST4 Telescope Driver (ASCOM) it gives me no choice. The guide relay option selected with ASI cam 1 or 2 can not verify if it works.
Can someone help me please. I am going crazy.
Many thanks in advance.
