Astrobug wrote:The 16,5 spacer is an adaptot from T2 to M48. The 21 spacer is T2 to T2.
About the right distance. Take account of the thickness of your filters.
55mm minus 1/3 of the filter thickness.
Maybe your flattener has enough tollerance.
1mm for astrodon 1.25" mounted.
The bottom line is that the 16.5mm spacer doesn't fit the flattener but the 20mm does. Why on earth would they include two different sized spacers?
6.5 for camera
20 for EFW8
1 for male to male adapter which doesn't match the picture in the manual.
10 for the spacer that was removed from the front of the camera
16.5 ZWO spacer that threads to the previous train but not to the SV reducer
Brings me to 54mm minus 1/3 of astrodon filters which is 1mm.
Is this correct? Even then this is 53mm.
The front of the reducer comes off but it appears to be some kind of its own spacer and the threads it comes from are the same and of no help in mating the 16.5mm ZWO spacer.
This is kind of ridiculous. If someone can figure out how to make this work without spending $79 then I'll buy you a beer. Maybe I have the order of these components wrong. I've tried every combination I can think of. Having it fit but wrong spacing, or right spacing and no fit is frustrating to say the least.
I know I am not the only one with this setup. All I want is 27.5 spacing from (M42 X.75) threads to the front of the filter wheel.
