Hi All,
Usually, when you try to set an appropriate offset/brightness value, you will have to check the histogram.
When you increase the offset, you will find the waves of histogram will move to the left.
Usually, A good offset will show the crest of the wave on the histogram of your photo.
So do not worry about the offset, it is easy to use.
Thanks
Chad
