I have an asi174mini with which I am experiencing problems. Some trivial, but others serious.
I have the 174mini plugged into a usb3 port, but when I display the contents of the device ASI_CAMERA_INFO returned from ASIGetControlCaps, IsUSB3Camera is true and IsUSB3Host is false (the opposite of reality).
I also find that this camera fails exposures frequently (ASIGetExpStatus returns a status value of ASI_EXP_FAILED). The failure always occurs at the very end of the exposure, and the longer the exposure time (especially multi-second) the more likely the exposure will fail, but always right at the end of the exposure time (even when I call ASIGetExpStatus in a tight loop).
This is on an idle system with no other cameras active, and nothing else on that specific usb bus.
Is there a way to obtain more detailed information about why the returned status is ASI_EXP_FAILED?
If I plug the 174 mini into the usb hub of a 294MC pro then neither camera works well (or sometimes not at all, with ASIGetNumOfConnectedCameras returning 1 or 0). But if I plug them each into their own usb3 port then both work: the 294mc pro works flawlessly, but the 174 mini behaves as I have described above.
I can use other USB devices plugged into the 294mc pro's usb hub with no problems.
This has lead me to believe that there is an issue with the 174 mini's usb handling.
Is this a common problem with the 174mini, or should I return the camera for a replacement?
If it is common, then how are folks dealing with the 174mini's frequent exposure failures or inability to play nicely with other usb devices?
Thanks,
Leonard
Linux star 4.10.0-42-generic #46~16.04.1-Ubuntu SMP Mon Dec 4 15 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
