I hope someone can help me.
I have a new ZWO ASI 1600MM-Cool with an 8 pos. filter wheel and ZWO original filters. I use it with a Samyang 135/2.0 lens.
My problem is that I can´t get an even focus plane even if I stop the lens down to f/4. If I get the stars pin sharp in the middle, I get odd stars in opposing cornes of the image. If I adjust it to be good in two corners + the middle, I get elongated (radially) stars in the other two corners. See attached image, autostretched in Pixinsight.
What could be causing this? It shouldn´t be a spacing problem since I use the camera + filter wheel + ZWO EOS adapter for Canon EF-mount lenses. Added up, that should work.
I have tested the lens itself using the Lonely Speck aberration test chart and it is pin sharp to the edges even at f/2 on a full frame camera.
Any ideas? I´m pulling my hair here...
