Hi,
If you want to use ASCOM, you should install it. After that, then you can see the ASCOM selection in the AstroLive.
Install ASCOM steps is on our websit: support-> software -> ASCOM driver.
Please install ASCOM Platform first, then install our ASCOM driver.
After that, start the Astrolive, then you should see the ASCOM Selection.
It should works fine.
For the dll, I had said at the begining....this software has been stopped updating for a long time, because our SDK interface has changed a bit before, so I'm not sure if it will still be used properly. I followed this issue, and I am sure that it could not work now. Because we add a initial function, the software need to call this function before open it. But the AstroLive do not. That's why you can not open it.
But for ASCOM, we will change our SDK to meet the ASCOM interface, then the software will call the ASCOM interface. So it should works fine.
Thanks
chad
