Hi I am an ASI120MC owner, I ask: where is the IR_CUT filter I would like to delete it thanks
just open the camera by unscrew off the cover
then you will find the IR-CUT filter
Sam wrote:just open the camera by unscrew off the cover then you will find the IR-CUT filter
What would it be? that round slide fixed by a ring if you say thank you, another question? if I delete the filter, can I shoot in the infrared? Thank you
yes, you can shoot the IR without IR CUT window
