Hi
I am having a problem with my 1600MC-Pro. I use it with cooling at -20C, and Unity gain (139). I have done a series of 180 second subs, and they all show some patterning in the background.
The pattern I am talking about are the curving lines, mainly visible in the centre of the above image as light curving lines against the slightly darker background. This image is a processed stack of images. However the same pattern is visible in all of the subs (but fainter and harder to show). I have just taken subs again one month later and get exactly the same background pattern, which has made me think this might be a hardware issue?
You can also see that processing has introduced inverse vignetting that I have been trying (for one month!) to get rid of. Despite many different processing techniques, and using flat frames taken in various ways for various lengths of time, I have been unable to avoid the inverse vignetting (dark in the centre and light outside). The individual subs look ok, it is just when stacked that the inverse vignetting shows up. There are what I assume are dust shadows in the individual subs, so removing the vignetting as gradients doesn't help much. This image shows an individual sub with the dust shadows next to the processed stack.
So I have two issues - the curvy lines in the background, and the inverse vignetting. I have spent a month working on the inverse vignetting and have not been able to get rid of it. I now wonder if the two issues are perhaps linked and caused by a hardware issue?
Phil
