Thanks for the reply, Sam. It is good to know that the settings are a okay, but i think i have another problem. Whenever i set the brigthness setting (under "image controls") to a value just a bit higher than zero, the whole picture is getting just white. But i think this is no problem with the camera, probably it is the user doing something wrong in sharpcap :-)
I now must only figure out how to tell the camera to use the correct offset. Note: I do not use ASCOM, i use the native driver. Do you have any hint regarding this?
