That's correct, I set the temperature to -20 it goes to this without a problem. I start imaging and then several hour later the temperature starts to rise as if the cooler has been turned off. The only way I can get cooling to start again is to shutdown APT and remove power to the camera, power up the camera again and everything works fine, the cooler cools the camera back to -20.
James
