The camera is fine over USB, the issue seems to be come down to the LAN cables. At this point ive tried 5 different brands and styles of network cable and two different extenders. Every piece of equipment that I own works over these cable except for the ZWO camera. 4 different DSLRS T5, 70D, 7D and a 7D MarkII, and an mount, also tried three different laptops, all of them are current technology I5, I7, I3. The I7 laptop is my workhorse computer, It is configured to run resource intensive graphics programs. Im running 16Gb Ram on a 64bit system which is powered by a quadcore cpu .
Even using a 6 inch piece of LAN cable between the ZWO 290mm mini camera and the laptop prevents the camera from passing data. The device will connect, but will not feed / stream image data.
The only think I have not tried was adjusting the cameras throughput, im going to look into doing that now and will post back . Id really like to get this working before the weather breaks for the season.
Thank you
