Hi Don
thanks for using ASICAP and feedback
this is our first release of the software, so it's not perfect
and we didn't add all functions to this software because we wish to keep its simplicity
but welcome to submit your feature request, we will discuss and may add it to our next version
ASICAP is a video capture software and mainly for planetary imaging
we will release more software for other usages
such like DSO imaging and Live stacking
1. As mentioned it could use a crosshair function.
we will add it to our next version
2. Couldn't figure out how to capture sequential .FIT images. I set the limit to 10 frames and nothing happened when I clicked the Camera Icon other than I manually captured one frame.
you are correct the limitation is only for video capturing, the snapbutton is only used for snapshot one frame
I think we will add one autorun button to do such job
3. .FIT files were not useable in AstroToaster which uses DSS as an engine. But AstroToaster was able to work with files captured as .PNG when the program was set not to capture in Raw format.
we will check this issue
4. I'm not sure but there doesn't appear to be a way to save a cameras profile.
we will consider where to add it
